Identifying a genuine 9315 Submariner bracelet
These Swiss bracelets were found most often on Submariners after the Swiss 7206 rivet bracelet was discontinued. I believe Rolex introduced these bracelets around 1969 and they continued in use until the late 1970s on the Rolex watches and are found much later on the Tudor watches.
Some of the attributes of this bracelet are:
1) There are 12 links total on the bracelet, referred to as "folded links." Some of the later parts books
show these bracelets with 13 links.
2) The clasp does not have a thumbnail recess like found on the later 93150 bracelet.
3) The flip-lock clasp is smooth on the top missing the two etched lines found on later 93150 clasps.
4) Early models had 380 end links with a T-bar shaped piece that went through the end link and was crimped to the last link of the bracelet. Later, around 1970, the end links changed to 280 which did away with the T-Bar inside of the end links and instead, the 280 end link had a slot cut on the back side of the end link where the large center loop on the last link on the bracelet passed through and into the end link.
Once this end link was properly inserted into the last link of the bracelet, the spring bar would be inserted into the end link where it passed through this loop from the last bracelet link thereby securing the end link to the bracelet.
5) It is possible to have clasp blades without a date stamp normally around 1973 -1974.
6) 9315 is stamped on the outer side of the last link which is found on the seven-link side of the bracelet.
7) 10 holes on each side of the clasp for adjustments.
The photos depicted here are from a bracelet found on a Submariner 1680 with a 1971 case back. The bracelet clasp is not dated which is not uncommon for these early bracelets. Additionally, the word PATENTED found on the diver's extension is misspelled and reads PATETED. (Rolex later corrected this error.) Not all of the 9315 diver's extensions contain this spelling error.
- Img_2098sm.jpg (36.32 KiB) Viewed 7950 times
- Img_2100sm.jpg (41.75 KiB) Viewed 7950 times
- Img_2093sm.jpg (54.89 KiB) Viewed 7950 times
- Img_2101sm.jpg (75.22 KiB) Viewed 7950 times
- Img_2102sm.jpg (64.67 KiB) Viewed 7950 times
- Img_2088sm.jpg (74.61 KiB) Viewed 7950 times
- Img_2082.sm.jpg (74.13 KiB) Viewed 7950 times
- Img_2081sm.jpg (52.16 KiB) Viewed 7950 times
- Img_2092sm.jpg (56.85 KiB) Viewed 7950 times
- Img_2090sm.jpg (59.8 KiB) Viewed 7952 times
- Img_2078sm.jpg (41.15 KiB) Viewed 7952 times
- Img_2079sm.jpg (46.29 KiB) Viewed 7952 times
- Img_2073sm.jpg (91.55 KiB) Viewed 7952 times
- Img_2074sm.jpg (87.67 KiB) Viewed 7952 times
- Img_2076sm.jpg (90.63 KiB) Viewed 7952 times
- Img_2066sm.jpg (76.58 KiB) Viewed 7952 times
- Img_2067sm.jpg (88.9 KiB) Viewed 7952 times
- Img_2068sm.jpg (35.61 KiB) Viewed 7952 times
- Img_2069sm.jpg (57.84 KiB) Viewed 7952 times
- Img_2070sm.jpg (67.2 KiB) Viewed 7952 times
- Img_2071sm.jpg (56.41 KiB) Viewed 7952 times
- Img_2072sm.jpg (43.83 KiB) Viewed 7952 times
- Img_2065small.jpg (54.77 KiB) Viewed 7952 times
- Img_2087sm.jpg (56.16 KiB) Viewed 7952 times
- Img_2053m.jpg (73.06 KiB) Viewed 7952 times
- Img_2054sm.jpg (38.66 KiB) Viewed 7952 times
- Img_2055sm.jpg (86.57 KiB) Viewed 7952 times
- Img_2056sm.jpg (48.56 KiB) Viewed 7952 times
- Img_2057sm.jpg (62.41 KiB) Viewed 7952 times
- Img_2058sm.jpg (48.7 KiB) Viewed 7952 times
- Img_2059sm.jpg (55.93 KiB) Viewed 7952 times
- Img_2060sm.jpg (38.11 KiB) Viewed 7952 times
- Img_2062sm.jpg (52.3 KiB) Viewed 7952 times
- Img_2063sm.jpg (37.58 KiB) Viewed 7952 times
