Difference between GMT 16760 and GMT 16750/16700/16710 hands
In summation, while the hour, minute and 24-hands between the 16750, 16700 16760 and 16710 models are interchangeable, as well as the sweep seconds hand being interchangeable between the 16750, 16700 and 16710, the GMT II 16760 sweep seconds hand is unique with its longer mounting post and intended for specific use with the GMT II 16760.
GMT and GMT II Movements:
GMT 1675: 1565 (marked 1560 on the bridge, replaced by caliber 1575 around 1965)
GMT 1675: 1575 (marked 1570 on the bridge - hacking feature added during early 1970s)
GMT 16750: 3075 (with quick-set date setting function)
GMT 16700: 3175 (replaced the GMT 16750 with quick-set date setting function)
GMT II 16760: 3085 (semi quick-set date setting function with independent hour hand)
GMT II 16710: 3185 (semi quick-set date setting function with independent hour hand)
GMT II 16710: 3186 (semi quick-set date setting function with independent hour hand. Found in the GMT II during
the last year or two of production. )
(Click on the photos one time to bypass the scrolling bars.)
- Img_0090.sm.jpg (92.89 KiB) Viewed 62886 times
- GMT 16760.top.small.jpg (68.2 KiB) Viewed 64158 times
- GMT 16760, TOP.small.jpg (94.25 KiB) Viewed 64158 times
- GMT 16750.top. small.jpg (79.75 KiB) Viewed 64158 times
- gmt 16750. bottom. small.jpg (70.37 KiB) Viewed 64158 times
- gmt 16760,backside.2.small.jpg (51.18 KiB) Viewed 64158 times
- GMT 16760 SET, backside. small.jpg (70.29 KiB) Viewed 64158 times
- GMT 16760 and 16750.jpg (59.83 KiB) Viewed 64158 times
